1967 F100 4BT cummins daily driver build
4 Attachment(s)
So I have been working on this since July now. I think I finally have gotten far enough to start a thread on it. This is going to be my daily driver. Cummins 4bt with compound turbo set up, "beefed up" mustang II front suspension, Phoenix transmission diesel specific built 700R4 OD tranny, dodge steelies, and fully boxed frame.
So here it goes....... removing the I-Beam suspension Attachment 201401 Attachment 201402 Attachment 201403 Attachment 201404 |
7 Attachment(s)
Boxing the frame, fabbing up the mustang II...........
Attachment 201394 Attachment 201395 Attachment 201396 Attachment 201397 Attachment 201398 Attachment 201399 Attachment 201400 |
5 Attachment(s)
Installing mustang II and some of the upgrades........
Beefed up speedway motors lower control arms; added gussets and larger ball joints..... Attachment 201389 Attachment 201390 Attachment 201391 Attachment 201392 Attachment 201393 |
8 Attachment(s)
welding the MII in..............
Attachment 201381 Attachment 201382 Attachment 201383 Attachment 201384 Attachment 201385 Attachment 201386 Attachment 201387 Attachment 201388 |
8 Attachment(s)
finishing up the front suspension. I didn't like the extended length tie rods so I put some heim joints and billet tie rod sleeves on. 700lbs springs with QA1 coil overs.
Attachment 201373 Attachment 201374 Attachment 201375 Attachment 201376 Attachment 201377 Attachment 201378 Attachment 201379 Attachment 201380 |
6 Attachment(s)
And on to getting the motor mounts fabbed and the cummins in the chassis. And yes, you are seeing that right; the engine is set waaaay back and I cut the firewall. I will have to modify the windshield wiper mechanism a little, do a street rod gas pedal set-up, and some custom carpet.
Attachment 201367 Attachment 201368 Attachment 201369 Attachment 201370 Attachment 201371 Attachment 201372 |
4 Attachment(s)
So this is where I am at. Engine is set in the chassis and the cab is in place. I will post pics of the rear frame work next weekend.
Attachment 201363 Attachment 201364 Attachment 201365 Attachment 201366 |
Subscribed. That's awesome!
I have a question of my own ignorance, why did you set the engine so far back? I think I am aware that the newer trucks are similar, but is there a reason? :-huh
The transmission bell is out in the engine bay on my slick. John :-X06 |
Originally Posted by jowilker
(Post 12521955)
That is a clean build. As a bonus you have no worries about making that tall engine and the crossmember or steering get along.
Nice fabwork!!!
How much space are you going to have in between fan and rad? Looks like ALOT!!! |
Sweet build! subscribed
Wow! You sir are a clean welder and superb fabricator
Subscribed.r |
Man! This makes me want to learn how to weld so bad! I'm glad I found that weld tutorial in the older truck thread
