side panel oil leak?
Old 11-19-2012, 10:32 PM
heartlandcowboy90's Avatar
heartlandcowboy90
heartlandcowboy90 is offline
I have a 90 f150 4.9l 2wd auto and it appears to be slowly leaking oil from a mysterious place just behind the oil filter. Is there some sort of access panel there? Is it a normal thing for it to leak? Can I purchase a gasket for this?
Old 11-20-2012, 05:30 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
To answer your questions, yes and yes. Get the Fel Pro blue silcone gasket.
Old 11-20-2012, 06:25 AM
bdelmar2's Avatar
bdelmar2
bdelmar2 is offline
The oil switch might be leaking a little as well. Its right in that area.
Mine was leaking a small amount of oil and I replaced it yesterday. Since I had to mess with it anyway I put a T fitting and a 2" nipple in and installed a mechanical guage at the same time.
Old 11-20-2012, 07:56 AM
jas88's Avatar
jas88
jas88 is offline
Try tightening the lifter cover bolts first.
Old 11-20-2012, 07:57 AM
Intimnasc's Avatar
Intimnasc
Intimnasc is offline
When it is covered in oil that side panel looks intimidating but it is really easy to replace. Get some degreaser and go to the local carwash before you start and its pretty straight forward.
BullRidnRenegade
02-24-2012 10:54 AM
Tod1985F250
01-28-2009 06:42 PM
Suber
04-08-2007 03:40 PM
rchrdcary
12-20-2004 01:58 AM
Quick Reply: side panel oil leak?
