Oil Leak?
Old Feb 23, 2012 | 04:22 PM
BullRidnRenegade's Avatar
BullRidnRenegade
Oil Leak?
the bottom of my 7.3 is covered with oil and drips regularly everywhere its parked. I've had the truck for 3 months and have only put about 4 quarts into it. I cant see any sign of leakage from under the hood. Where's this oil coming from. It looks like a larger leak on the ground and on the underside of the truck, but the oil loss in minimal.
Old Feb 23, 2012 | 07:29 PM
tje2015's Avatar
tje2015
Could this be oil leaking from the oil pan? Maybe a bad Gasket?
Id look really hard around that area and above that area for the source.
Old Feb 23, 2012 | 09:59 PM
84-6.9L's Avatar
84-6.9L
Start by tightening up you valve cover bolts, then try to clean things up. also oil filters should be tightened 1-1/2 turns after the gasket makes contact, any less and they will loosen and start to leak.
Old Feb 24, 2012 | 10:54 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Without more info on the drip location it's hard to say ...
Valve covers are known for coming loose and leaking.
Oil Sending Unit.
Front and rear main seals.
Best thing to do is clean it up so you can trace the drip.
-Enjoy
fh : )_~
92aeroXLT
Aerostar
40
Jul 18, 2012 09:34 PM
Tod1985F250
Jan 28, 2009 06:42 PM
inline_6
May 30, 2007 03:56 AM
Suber
Apr 8, 2007 03:40 PM
Border3899
Dec 16, 2002 11:21 AM
