Candy Cane's Electrical Projects
It was pretty easy, Just be sure to have the Ford schematics and label all the wires. Volt/Ohm meter would be best but a test light would work. Take your time and have fun.
He just bought the new fuse block, not the hole harness. Read the right up, tells of a couple of problems and the fix.
https://www.ford-trucks.com/forums/1...l#post12969154
I am doing the under the hood power center from a newer Ford. Mostly for trailer lights, doing a mod similar to the headlight one you did, but for the trailer lights. But, might be doing some more for the headlights.
Question, did you have 1 relay for each headlight, or was one for low beams, and one for high beams? And what did you use the third relay for? Or am I being the one who needs to read your build thread more?
Help on Fuse Block
I just purchased the Painless Performance 14 circuit fuse block and need help figuring out where to install some of the wires that are not labeled on the new block. Looks like you did this a while back and you know what your doing. Let me know if you can help walk me through some of the steps. Thanks
sere0501
01-10-2015 12:13 PM
bpimm
12-17-2013 03:53 PM
boulderguy
30
02-29-2012 06:34 AM
