94 f150 4.9L 204K miles e40d problem
Hi. New here...Daughters 94 f150 started leaking transmission fluid from the bell housing, so she parked it for 2 years...Now I have been nominated to fix it...
Truck was running good when parked. Got it started (Just charged battery and started it up), and backed it up. Reverse is good and solid. When I tried to move it, it wouldn't move in drive. Starts to engage, then drops out. Pulled into first, and the truck moves, but have to have high rpm.
Replaced tc seal, filter and fluid, (12 quarts). No change... Ran it down the road, had to start off in first, good power up to about 35, shifted to second, it shifted...ran up to 45, then shifted into drive, it shifted, and maintained power. Had to slow so stopped and turned around, tried moving out in drive, and it just kept dropping out. Returned home as I left...read a lot of this forum, and learned some but not enough..
Pulled codes 327,116,536,538. No transmission codes.
Any ideas?????Thanks in advance.
I will have to agree with Mark, sounds like a weak and/or leaking Forward clutch.
The Forward clutch applies for every Forward gear on this transmission.
According to my ATSG repair manual, with the gear selector in Low 1st, in addition to the Forward clutch, the transmission also applies Coast clutch and the Reverse clutch. in Low 2nd gear, the Coast clutch Intermediate clutch, Forward clutch and intermediate band are applied, also In Low 2nd the low/reverse OWC is over-running.
wait a minute... the truck is an F-150? with a 4.9L inline 6Cyl? I wasn't aware those came with E40D transmissions.
are you sure its not an AODE?
http://www.ricksfreeautorepairadvice...identification
08-23-2015 07:43 PM
aclaybor
04-01-2014 02:14 PM
DAAJR
11-10-2009 11:15 AM
