1978 - 1996 Big Bronco
94 Bronco E4OD probs...
Old Oct 29, 2007 | 10:16 PM
Stang5lgt's Avatar
Stang5lgt
My buddy was driving his 94 pulling a boat, when the truck stopped moving. He said the tranny was slipping. I was wondering if anyone knew of sensor on the tranny or if think is internal prob? Will not move in Fwd or Reverse.
Old Oct 29, 2007 | 10:51 PM
cajunland's Avatar
cajunland
Have you checked the fluid level and condition? Also pull codes? If the trans (or converter) are slipping, it throw codes?
Old Oct 29, 2007 | 11:07 PM
'94Nichols's Avatar
'94Nichols
i have an e4od in mine. a couple weeks ago, it wouldnt start moving til about 3500 rpm. my filter had fallen out. i put a new one in w/ b&m trick shift fluid and lucas transmission addative and it runs great now!
Old Oct 30, 2007 | 11:44 PM
mrknight01's Avatar
mrknight01
There is a input sprag in the trans that all the power goes through to drive the trans. Have him try it in 4 high and 4 low and with the overdrive off this will help to eliminate some parts in the line of power. When you turn off the O.D. in the E4OD before 96 it turns on the coast clutch which helps the input sprag turn the rest of the trans.
P.S. it is best to tow with out O.D.. drive uses less parts in the trans and make less heat.
Old Nov 1, 2007 | 06:26 AM
Stang5lgt's Avatar
Stang5lgt
Tried OD switch no difference. He said that reverse is working.
Old Nov 1, 2007 | 09:49 AM
mrknight01's Avatar
mrknight01
Unhappy
sounds like he burnSounds like he burned up the forward clutch pack. Only fix is a overhaul. Tell him to look for a ATRA shop there
http://www.atra.com/source/amembers/...searchtype=reb . Good warranty and then check the BBB for complaints on the shop he picks.
Old Nov 1, 2007 | 10:42 AM
s1120's Avatar
s1120
I have had mine act up twice and I thought I toasted it. Once was the TPS on the throttle body, and the other was the MLP switch.
