Recently I got the chance to buy my first truck back that I sold 23 years ago sounds great EXPECT something is going on with the fuel system. The truck is a 95 f150 dual tanks . I am no mechanic by far, but I can do the little things brakes alternator etc. . So the issue I'm having is getting fuel into the engine. My dad said I would need to remove the gas tank and replace the pump. MY QUESTION IS CAN I NOT PUT AN AFTER MARKET PUMP BETWEEN THE FUEL TANK AND THE MOTOR
THANKS FOR ANY ADVICE
It sounds like it's working fine, your next step would be to turn the key, let the pump run until it stops and then seeing if the truck starts normally.
If it doesn't, then you're probably looking at a clogged filter somewhere.
