Bringing her back
Old Jul 31, 2019 | 08:01 AM
Kelly Bogue's Avatar
Kelly Bogue
Bringing her back
Recently I got the chance to buy my first truck back that I sold 23 years ago sounds great EXPECT something is going on with the fuel system. The truck is a 95 f150 dual tanks . I am no mechanic by far, but I can do the little things brakes alternator etc. . So the issue I'm having is getting fuel into the engine. My dad said I would need to remove the gas tank and replace the pump. MY QUESTION IS CAN I NOT PUT AN AFTER MARKET PUMP BETWEEN THE FUEL TANK AND THE MOTOR
THANKS FOR ANY ADVICE
Old Jul 31, 2019 | 08:30 AM
subford's Avatar
subford
Sounds like neither fuel pump will run. So your fuel pumps may be OK.
Not easy to put on a frame pump on a duel fuel tank truck.
Tell us you problem with the truck and we will try to help you.
Old Jul 31, 2019 | 09:03 AM
Kelly Bogue
Began with sputtering then it started dying and will not crank now its trying to start just not getting the fuel to bust off
Old Jul 31, 2019 | 09:13 AM
Magnum3672's Avatar
Magnum3672
When you turn the key do you hear the pumps engage?
If you do, there's probably a clogged filter somewhere in the system that's preventing fuel getting to the engine.
If you don't, it may be a bad pump or it may be a bad fuse/wiring along the path somewhere.
Old Jul 31, 2019 | 09:29 AM
Kelly Bogue
I dont think I heard the pump come on when it ran fine
Old Jul 31, 2019 | 09:43 AM
Kelly Bogue
So when I turn key half turn I hear a hum like a pump or motor running, but once key is turned all the way I cant heat bc of everything else happening
Old Jul 31, 2019 | 09:51 AM
Magnum3672's Avatar
Magnum3672
That sound is the fuel pump.
It sounds like it's working fine, your next step would be to turn the key, let the pump run until it stops and then seeing if the truck starts normally.
If it doesn't, then you're probably looking at a clogged filter somewhere.
Old Jul 31, 2019 | 10:12 AM
DBANDGB's Avatar
DBANDGB
Change the filter first.
Old Jul 31, 2019 | 08:09 PM
Kelly Bogue
Found out from previous owner that truck ran on 2nd tank no problem would not switch over and run off 1st tank .
.:1978_Ranger:.
13
Mar 20, 2014 08:16 AM
Ty_Deschaine
13
Jun 9, 2012 07:00 PM
scottie2hottie
Feb 10, 2007 09:06 AM
tony b
Nov 4, 2006 10:10 AM
chrisrog
Jul 13, 2001 12:15 AM
