ABS and AdanceTrac
ABS and AdanceTrac
Ok, I have a 2003 Ford Expedition Eddies Bauer (5.4), with the Advance trac system. The Truck has 105K miles on it and seems like very since I have hit that 100K mark it has been nothing but problems.
<O</O
<O</O
First issue: ABS LIGHT; My ABS light is on I had the Rear Right wheel Speed sensor replaced already. The Code I'm getting is C1165 and C1175. What's the Chances of both sides going out at once? The Truck as no trac at all, it will spin all day on wet grass (A lil Frustrating when you use it to pull a 21ft Ski boat!) Any advice?
<O</O
<O</O
Second Issue: All Wheel Drive/ Four Wheel Drive/ Four Low..... When I turn my **** on the dash to any position the only light that comes on is the 4WD light, not the ALL wheel or the 4WLD. And to top that off it blinks about 4 times and then stays off. The truck itself is not in 4WD though (Self Testing on Concrete/also on wet grass) even with the **** turned to 4WD it still has no traction. <O</O
<O</O
Could these 2 issues be 1? Can anyone help? Any advice is greatly appreciated.
<O</O
<O</O
<O</O
<O</O
<O</O
