Sponsored by: Auxito
ABS Help.. Module keeps running.
Old Sep 5, 2008 | 06:25 PM
hugo69's Avatar
hugo69
After pulling my camper to my brothers storage shed my ABS light came on in my 2000 F150. After parking the camper, I pulled my truck around to about 100 feet to go into the house. When I shut the truck off, I heard a noise coming from under the hood. I looked at the manual and found the fuse to the ABS module #102 and pulled it and it finally shut off. I then went to a dealer and he pulled these codes.
B1676
Supply Voltage Out of Range ABS<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
C1185 ABS Power Relay Output Circuit Failure ABS<o></o>
C1096 ABS Hydraulic Pump Motor Circuit Open ABS
Can anyone tell me what the next step should be? Is it the module that is bad? I did change the rear sensor a year ago. Could it be bad again and make the module continuously run?
</SPAN></SPAN>
Old Sep 6, 2008 | 09:54 PM
Ultramagdan's Avatar
Ultramagdan
I doubt it's the rear sensor. Let's see if we can get some more help.
Old Sep 13, 2008 | 06:02 PM
hugo69's Avatar
hugo69
Does anyone have any ideas? Should I start looking around for a Module?
Old Sep 18, 2008 | 02:39 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
You may have a bad ABS relay. It may be causing the pump to run continuosly. Dan.
Old Sep 28, 2008 | 07:21 AM
hugo69's Avatar
hugo69
Where would the ABS Relay be located? Looked in all my books and can't find anything?
Old Aug 23, 2010 | 06:29 PM
loud_mouth22's Avatar
loud_mouth22
I'm having this same problem can anybody help please
Truckandute
Aug 28, 2014 01:42 PM
Jesser02EX
35
Jul 14, 2014 12:17 PM
neoinbiz
Dec 14, 2012 02:10 PM
kontoboy
Sep 12, 2010 10:58 PM
RÖENTGEEP
15
Dec 22, 2008 07:02 PM
