rpm to high
I think the simplest would be one of the cast iron toploader 4 speeds, or as Ford called them 3+OD. I'm not posative but I think it would even bolt right to your bellhousing but you might need to change the bellhousing too. There are at least 4 other overdrives Ford has used over the years but they are either harder to find or more work to swap over.
don't get it confused with a regular toploader out of a car....the 4th gear on those is 1:1.....the 3+OD I believe came exclusively in trucks....check the link The Borg-Warner Overdrive Transmission Explained- FORDification.com
They offered a 3spd OD model in these trucks. T85? sumthin or other. My '64 wagon had one(but it was the small bearing retainer version for the 5bolt bellhousing).
Friend had one behind a 390 in his bumpside truck. Comes with a cable under the dash to control the OD. Looks about like a std 3spd, but slightly different tailhousing.
Might be kinda hard to come by, not sure how popular. The newer SROD 4spd(OD model) will need a floor shifter installed.
Corner Gas
05-26-2007 10:28 PM
toyshop
04-20-2002 04:24 PM
