A toploader should bolt right up, you will need a shifter. Some of the early Bronco houses sell the shifter & there's always ebay. You can get close ratio which pulls better on the road or an overdrive that uses basically the same gearing plus an overdrive.
I think these sites can help you find the tranny you need.
