IPR Socket
Old 09-11-2012, 11:51 AM
Sullid01's Avatar
Sullid01
Sullid01 is offline
IPR Socket
Will this one work? I like the Lisle tools and this is a lot cheaper than the other options. I found something about how they changed the design of the IPR in 2005 so I wasn't sure if this tool would work on my 2006.
Lisle 68210 IPR Socket for Ford Diesel : Amazon.com : Automotive
Old 09-11-2012, 11:54 AM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
It's worked for me.
Old 09-11-2012, 12:00 PM
Sullid01's Avatar
Sullid01
Sullid01 is offline
sweet! Are any of those other specialty tools all that necessary?
OTC 6594 Oil Line Disconnect Tool for Ford : Amazon.com : Automotive
OTC 6766 Injector Harness Connector Release Tool for Ford 6.0L : Amazon.com : Automotive
They are much cheaper than they used to be
Old 09-11-2012, 01:17 PM
wulfman's Avatar
wulfman
wulfman is offline
If you have the right socket just make one .
Old 09-11-2012, 01:18 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
Same one I used. Gotta love Amazon Prime, had it in two days just in time for the job
Old 09-11-2012, 01:28 PM
texastech_diesel
Token Redneck
The injector harness tool is a ripoff, you can use a 19mm socket to push the connectors through.
Old 09-11-2012, 01:49 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
You won't need the oil line disconnect tool for your 06.
Old 09-11-2012, 02:01 PM
Sullid01's Avatar
Sullid01
Sullid01 is offline
I love Prime. Just ordered it. Thanks everyone else for the advice - I am a tool junkie and sometimes need to be reigned in. It is such a pain in the a$$ to struggle for an hour, then see someone with just the right tool do it in 30sec. I am getting prepared to try the STC repair myself - it will be (by far) my biggest undertaking yet.
Old 09-11-2012, 04:14 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is online now
The Lisle IPR socket will work fine on your '06 and the ridge on the outside makes it small enough to work on the earlier engines also. You will need a torque wrench with a small head to clear the intake manifold (if it's in there), or put the calibrated elbow to it. STC aint too bad you can do it. Some bolts are stubborn to get out and a couple are stupid hard to get to but not that bad of a job overall.
Old 09-11-2012, 08:36 PM
Sullid01's Avatar
Sullid01
Sullid01 is offline
Rusty,
Thanks for the vote of confidence. I don't do anything quick so it will probably be another month ordering parts, then I'll watch a few videos and read the manual, read a boat load of posts, then I'll psych myself up and dive in. I'm flushing the coolant first, to see if I need to do the oil cooler as well. Just the flush will probably take the better part of a weekend - my wife says I really know how to make a project out of it - Dan
aresixx
Garage & Workshop
112
02-07-2005 06:59 PM
BradysDad
Garage & Workshop
01-17-2005 06:57 AM
AOGDEN
Garage & Workshop
05-25-2003 02:52 PM
Quick Reply: IPR Socket
