53 build update
Old 08-27-2012, 06:46 PM
71mach351's Avatar
71mach351
71mach351 is offline
53 build update
Check a few more items off the punch list. Disk brakes....check. Firewall mounted power brake booster....check. Plumb all brake lines...check. Under bed Mustang tank...check. Test fit front clip with modified lower valence (no directionals)...check.
Thanks to the how-to posted here for the tank install. I did have a few problems, however. The tank body was actually wider than the inner frame. I hade to grind down about a quarter inch from each side of the lower frame for the tank to fit. Also, the how-to did not have stock rear suspension. The tank frame has to be mounted about a half inch from the bottom of the frame to clear the rear spring mounts on the bottom of the frame. No big deal. Looks great.
New disk brakes.
New brake booster and brake lines.
Mustang gas tank.
Front end alignment. I removed the directional light housing humps from the valence. I going with directionals in the headlights.
Old 08-27-2012, 10:21 PM
das54's Avatar
das54
das54 is offline
look'n good. It took me years to get to where you are. keep up the good work.
Old 08-28-2012, 08:15 AM
1950 79 ford's Avatar
1950 79 ford
1950 79 ford is offline
Looks good. Just keep working at that pace and you will be done in no time.
Old 08-28-2012, 08:44 AM
Wayne S's Avatar
Wayne S
Wayne S is offline
Great progress it all looks good. I had the same issues on the tank install that you did. Did a little massaging here and there and it all worked out fine.
Old 08-28-2012, 09:31 AM
jaye's Avatar
jaye
jaye is offline
I made a frame out of 1x1 tubing and mounted my tank under the frame there is a small open space where I put a spacer(where the frame kicks up) This was I can drop the tank if needed without taking off the bumper to slide it out.
In this pic the bolts aren't tight nor is the spacer installed, to the far right is a "L" shaped bracket that is also bolted to the frame.
tractormanbill
17
02-05-2019 10:56 AM
Sickler1
05-19-2018 04:26 PM
1978crewcab
05-03-2016 09:39 PM
TheWiz427
23
10-02-2008 05:09 AM
oldjeep
10-16-2005 08:18 AM
Quick Reply: 53 build update
