Flathead oil pan with MII suspention.
Received 1,357 Likes
on
jersey joe
1956ford@optonline.net
Fatman
If we know the crossmember will be fitted with a Flathead, we add a notch to the crossmember to make that work (at no extra charge). If that asn't done at the time of the order, you could return the crossmember for us to do it. Or you could make your own notch 10" wide, beginning at the top front corner and going down to the rear lower corner.
Then box that open section for strength and staying clean. Since the crossmember is made with 5/16" wall steel tube, the beam strength will still be fine.
I would attach a photo, but this site won't let me do so (or at least I can't figure it out) Give us a call and we can email a photo of more info is needed, thanks
sdetweil
21
11-20-2010 09:13 PM
rtcalabrojr
02-13-2010 08:51 AM
lowtrkn2k
10-04-2008 08:24 PM
