Oil change question
08-08-2012, 05:31 PM
Oil change question
Well it looks like WallyWorld here has stopped selling
Rotella T6 15/40. They do have Rotella T6 5/40
The question is can I use that during the summer?
I will be driving from Washington into California,
Nevada, Oregon and Idaho.
Sean
08-08-2012, 05:41 PM
T-6 5W40 is a synthetic, 15W40 is dino and T-5 is a synthetic blend. Take your choice. T-6 is not a 15W40.
08-08-2012, 05:50 PM
Brain fart
For some reason I got the a 1 in there
It's Shell Rotella Synthetic 5W-40 Motor Oil, 1 Gal
Thanks
Sean
08-08-2012, 06:04 PM
Quote:
Originally Posted by
Yahiko
i'm running 5/40 now, in sunny so calif.
when hot, a 5/40 and a 15/40 will have the same
viscosity, that of a 40 weight.
it should make no difference.
08-08-2012, 06:24 PM
I use the 5W40 year round also. In the 100's the last week. The truck loves it and so does the turbo.
08-09-2012, 12:15 AM
Thanks guys I needed to know that also. I tryed to give some reps
but got the
You must spread some Reputation around before ..........
for both your two.
Big THANKS.
Sean
08-09-2012, 11:44 AM
on
T6 is all I use. But 5k changes are highly recommended with shorter intervals if you do a lot of towing.
08-09-2012, 12:47 PM
egregg57
T6 is all I use. But 5k changes are highly recommended with shorter intervals if you do tow.
I fixed it for you.......
08-09-2012, 12:49 PM
on
BPofMD
Thank you, sir!
coolfeet
04-23-2016 05:42 PM
clux
04-09-2014 12:13 PM
Headviking
07-15-2009 02:11 PM
blockmanjohn
06-03-2009 09:25 AM
04F-250mark
04-11-2009 08:03 PM
