15/40 synthetics??
Old Apr 11, 2009 | 10:54 AM
04F-250mark's Avatar
04F-250mark
15/40 synthetics??
It's oil change time again and for the summer I was thinking of going with
a thicker oil. Or is Rottella 5-40 good enough for summer pulling. The other question is are there any 15-40 true synthetics out there resonably priced?
Old Apr 11, 2009 | 12:07 PM
Thor80's Avatar
Thor80
Not sure about your area, but here at our farm store they have "Mystik" 15-40 synthetic. I looked at it the other day and its made by Citgo. I havent tried it yet, but I'm thinking bout going to it next oil change.
-Torsten
Old Apr 11, 2009 | 12:22 PM
CoastieMK's Avatar
CoastieMK
I know Royal Purple makes a 15W-40 synthetic, but its a little pricey, around $36 a gallon around where I'm at.
liv's Avatar
liv
5w40 synthetic is fine for summer pulling
I personally have never seen a 15w40 in synthetic. If you find one just remember to make sure its cj4 rated
Old Apr 11, 2009 | 12:53 PM
69cj's Avatar
69cj
Actually for the 6.0, CI4 plus or CJ4 is OK.
Old Apr 11, 2009 | 03:49 PM
juneau76's Avatar
juneau76
I run 5w40 synthetic year round, however, I live in the Northeast and don't see the high outdoor temps for as long as you do in AR.
Old Apr 11, 2009 | 03:55 PM
mnmwhit's Avatar
mnmwhit
Mobil -1 turbo diesel truck oil is good for all Temps. I believe is is the BEST oil for the PSD. its all I use. I pull heavy loads and I drive south every summer to Georgia every year. Ready about the oil wieghts and you will find that the 40 in 5W/40 is the important part for warm weather.
Old Apr 11, 2009 | 04:52 PM
barnbridge's Avatar
barnbridge
I agree, Mobil 1 Turbo Truck 5W-40 is the best for the 6.0. I've done used oil analysis on several oils and the Mobil results were the best. Only problem is I can't get it here in SE PA, they say the refinery is still down from hurricane Katrina.
Old Apr 11, 2009 | 05:17 PM
69cj's Avatar
69cj
I use the Rotello 5w40 here in s. ca. Summertime Temps can go from 100+ degrees down to the 30's when climbing from the hi desert to 11,000 feet and have had no problems.
Old Apr 11, 2009 | 06:53 PM
woodrow151's Avatar
woodrow151
shell makes a pure synthetic its call Shel Rimula 15-40 it comes in quart size contaniers. i had to use it in the life boats here at work. cost? i dont know. it made for the dpf or for newer trucks.
Old Apr 11, 2009 | 07:02 PM
69cj's Avatar
69cj
No offense but if it is not readily available or out of reach, cost wise, for joe blow it doesn't matter how good it is.
Old Apr 11, 2009 | 07:07 PM
woodrow151's Avatar
woodrow151
wtf? its availible at the parts house any parts house heck its avalible at the ford place at the house.
Old Apr 11, 2009 | 07:44 PM
pjwoolw's Avatar
pjwoolw
Pay no attention woodrow. That guys fingers work before his mind thinks. Just noise.
The Shell product looks interesting. Checking the Shell website they seem to have quite an array of oils. Not sure at this point if all the oils in the Rimula portion are full synthetic or not. Would be worth a try if your not running a synthetic now. Keep me posted on the results. I'll check around some more and get my head clear on what's what with the Shell products.
Good luck!!
Old Apr 11, 2009 | 07:52 PM
04F-250mark
Thanks guy's I've read somewhere on here about valvoline or one of the big companies has a 15-40. I'm probbably gonna stick with rottella or mobile 1 thanks again
Old Apr 11, 2009 | 08:03 PM
mnmwhit's Avatar
mnmwhit
The refinery is back on line. I am getting it up here in Alaska again. I used Rotella syntetic this past winter and it sucked. Cold starts were no fun till I got the Wabasto.
