trans cooler lines - new cooler??
I'm replacing the radiator this weekend - and in doing so - hooking up the transmission cooler (that the PO had disconnected). SO, is there a "feed" or "return" side?
Is there a specific trans line I should plumb to the cooler? Or will either do the job?
To be totally clear; my truck currently only has a trucool trans cooler - all factory coolers were deleted by the previous owner. I will be re-introducing the radiator/transmission cooler.
Thanks All
Thanks All
I need the OTW cooler hooked up, and I don't trust cleaning the contaminated unit in the radiator. The way I see it, the only way to have the OTW cooler back is to replace the rad.
The receipt also had "transmission oil cooler" on it. Of course, it was the wrong one, I've already replaced it with a TruCool - but it still needs the OTW rad cooler.
That's not how it works. The bottom few rows are for engine coolant, just like all the rows above it.
The transmission cooler is inside the cool end tank. The trans cooler lines go in and out of this tank.
FOLLOW UP:
Mark, I've got the new radiator installed, and the Trans lines plumbed the way you've instructed.
I'm now running from the front of the Trans, to the radiator, then to the grill mounted aux cooler, and back to the rear of the trans. The factory trans cooler (low in the bumper) is still not hooked up.
Temps were around 130* at idle, before driving. Test drove (empty/no trailer or heavy load) about 15 or so miles in 91* ambient air, a decent mixture of traffic - no speeds above 45. The trans temp reached 176* or so.
I'm monitering via OBD with an Aeroforce Interceptor scan gauge (I don't know where it gets its readings).
Stinky1
12-14-2012 11:10 AM
dantsg
06-15-2009 09:59 PM
82f3504x4
05-12-2008 06:25 PM
BIGFISH70
06-19-2007 10:07 AM
