2001 trans cooler
Old Feb 12, 2004 | 10:52 PM
honeyb's Avatar
honeyb
2001 trans cooler
i read on a post about some of the 2001 having a better trans cooler than others, could someone fill me in here, i just bought a 2001 350 and would like to know if i need to upgrade or something
thank you,
courtney
Old Feb 12, 2004 | 11:57 PM
Fordman4x4's Avatar
Fordman4x4
Follow your cooler lines from the tranny to the front of the truck. See if the lines go up into the side of the radiator or to a cooler. The older setup is the stand alone air-to-oil cooler, the update was changing the radiator to one setup with the built in tranny cooler, water-to-oil cooler.
Nelson
Old Feb 13, 2004 | 07:44 AM
rmilchman's Avatar
rmilchman
I believe my 2002, has a radiator cooler that then goes to an external.
Old Feb 13, 2004 | 08:13 AM
mueckster's Avatar
mueckster
My '01 F-250 has the radiator cooler in the bottom tank then the external cooler in front of the radiator. I don't have a trans temp gauge, but I'm sure it cools much better than just the external cooler alone.
Old Feb 13, 2004 | 10:48 AM
honeyb's Avatar
honeyb
ok i will check the trans lines, if i have the new setup my trans lines go into the radiator, correct?
thank you,
courtney
Old Feb 13, 2004 | 04:25 PM
Fordman4x4's Avatar
Fordman4x4
you got it.
