Transmission Does Not Like Going Into Reverse
Just as the title states, for some reason my truck hates going into reverse. Typically it will work the first time of the day, but after that its half and half. Whenever I put the shift lever into reverse, nothing happens. You can tap the accelerator and it will SLAM into reverse but it sounds like the transmission just fell out. You can also put it in drive, then go back to reverse and it will work like normal. I have checked the fluid level and it is fine, the fluid looks nice and red, not burnt. The trans still shifts fine and doesn't slip. Does anyone have any idea what would cause this? The truck only has 56,000 miles and I am assuming it still has the original tranny fluid from the factory unless the PO changed it. I thought I would flush it and see what happens, but I don't want to spend $200+ on tranny fluid only to have it continue to do it. Any suggestions or tricks to try before dropping $200 on a tranny flush?
Thanks,
Kevin
Thanks,
Kevin
I thought the same thing Mark. All I know, is that my truck exhibited the exact same behavior as the OP, and as soon as I swapped VB's the problem went away. Don't know if there was something stuck in the reverse circuit of the stock VB or what...I just know I don't have the problem anymore.
My truck seemed to never do it first thing in the morning, but it would get worse when the truck was warm. Once warm, it wasn't consistent. Sometimes it would go into reverse like normal, other times it was a bit delayed, and then sometimes you could put it in reverse and it would sit there doing nothing until you gave it a bit of gas and it would slam into gear. Once in gear, it would never slip (even while backing trailer uphill). I know replacing the VB doesn't make a ton of sense, but it has not done it once since I swapped VB and fluid, where beforehand, it would do it pretty much daily. And yes, this is a GREAT excuse to upgrade to the JW VB...you will not be disappointed.
Motoxman_117
20
05-23-2009 12:04 AM
