4r100 loud bang then nothing
Old 06-16-2012, 03:31 PM
89ford73's Avatar
89ford73
89ford73 is offline
89ford73 is starting off with a positive reputation.
No warning signs just driving down the road it shifted _2_3 and as it was going into overdrive I heard a loud bang and then nothing no foreward no reverse it wont even try move .. I took the transfer case out and put truck in gear while running and the outut shaft doesnt even try to spin by itself.. I can spin it with my hand both ways freely with it in any gear besides park with motor running. I took the transmission apart completely and I found no broken or worn parts all clutches good all sprags working fine. Planetary gears look beautiful splines are fine nothing galded no holes in the side of the transmission nothing! All valves in VB move freely not stuck I even cut the torque converter open and everything looks good in there ..... I mean even I u drain every drop of oil out of the transmission and start the motor then there should be some type of internal drag that would cause the output shaft to spin itself a little bit right.?? im stumped.... I have rebuilt several of these 4r100's with good luck but this one is totally dead
Old 06-16-2012, 03:44 PM
89ford73's Avatar
89ford73
89ford73 is offline
The fluid level was perfect and beautiful. The filter was all the way in where it is supposed to be. All the bolts were proper torque no stripped or loose or too tight, the wires were all hooked up pump gears looked beautiful. Everything inside looked beautiful.. No popped out snap rings nothing
Old 06-16-2012, 04:05 PM
woodnthings's Avatar
woodnthings
woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
Are you sure it was the transmission? Have you checked the transfer case or rear end? I had a broken tooth from a spider gear in one of my old trucks, when it got picked up and went through the gears it was a loud pop and no forward or rear movement. Driveshaft just spun to the rear end.
Old 06-16-2012, 04:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Does the trans have pressure when it's running? You can check for pressure at the test port on the driver's side of the transmission.
Old 06-19-2012, 08:08 PM
STROKERDAN02
STROKERDAN02 is offline
STROKERDAN02 is starting off with a positive reputation.
had the same thing just happen not to long ago ended up being the front pump in the tranny went bad
TrailWhale
1999 to 2016 Super Duty
10-05-2015 01:13 PM
my996duc1
09-22-2014 01:42 PM
rwrobinson
17
03-06-2013 01:33 PM
kona56
04-05-2010 02:13 PM
arnegrant
08-05-2009 12:20 PM
Quick Reply: 4r100 loud bang then nothing
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
