Boost Gauge where do u run the hookup?
Old 06-19-2012, 09:15 AM
Yougotthehit's Avatar
Yougotthehit
Yougotthehit is offline
2000 7.3 just bought a autometer gauge where do I run the line too? Thanks fellas
Old 06-19-2012, 09:32 AM
jshalala's Avatar
jshalala
jshalala is offline
Check out Riffraff Diesels website, they have an AIH delete plug that screws into the spider. Thats what I bought, it is pre drilled to fit a boost gauge fitting without having to do any drilling yourself. Makes for a real clean install.
Riffraff Diesel Performance Parts: - AIH Delete Plug
I bought the one with the pre tapped hole. Get the one that works with the line that came with your gauge.
Old 06-19-2012, 09:51 AM
woodnthings's Avatar
woodnthings
woodnthings is offline
You can also use the included Tee Fitting by cutting the MAP hose. It runs from the spider to the MAP sensor on the right side of the engine compartment. The hose is covered with wire loom. You can simply use a 1/4" vacuum tee to splice in there.
The RRD AIH Delete plug is far cleaner and is also what I have done.
Old 06-19-2012, 10:06 AM
indyF-350psd's Avatar
indyF-350psd
indyF-350psd is offline
you can't fix stupid!
here's a pic for ya.....
Old 06-20-2012, 04:23 AM
primetime1267's Avatar
primetime1267
primetime1267 is offline
I just installed my riffraff AIH delete with boost fitting on Saturday.. Worked flawless, much better than tapping and having to clean drill bits.
Old 06-20-2012, 06:02 PM
danskool's Avatar
danskool
danskool is offline
Go Bills !
I did my connection point here -> 3-Gauge Install Pictures
Old 06-20-2012, 07:44 PM
magicsac1366's Avatar
magicsac1366
magicsac1366 is offline
i removed the aih plug and used that, people also do a "t-fitting" on the map sensor tube
and not to hyjack your thread, but did these intakes make any kind of difference that you noticed? i was thinking of getting them, if only to make it look cooler
Old 06-20-2012, 08:15 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
Notice anything different about his turbo? That's the reason for the intake difference mainly.
Old 06-20-2012, 08:34 PM
magicsac1366
LOL, wow, not untill you said somthing... i guess they did make a big difference then lol
Old 06-20-2012, 10:08 PM
indyF-350psd
the difference for me was how the intake "y" sat on top of the plenums....with the stock plenums and the pri's in there the plenums were too high and the "y" didnt sit on top of them right.....it was misaligned....the new plenums line everything up perfectly and are very nice....no boost leaks with the leak detector and ive boosted up to 40lbs again with no problems.....
edit: after re reading the above 2 posts did you think i had one of those cfm things? i thought you might have been following the plenum thread.....
Skip1970
03-30-2010 06:04 AM
crzycrazycarl
08-24-2008 12:01 PM
WHT00EX
08-06-2008 01:36 PM
02GrayPowerStroke
16
06-18-2007 04:49 PM
99superduty
10-28-2003 11:00 AM
Quick Reply: Boost Gauge where do u run the hookup?
