Boost gauge
Old Aug 6, 2008 | 07:57 AM
WHT00EX's Avatar
WHT00EX
Boost gauge
This might be a stupid question, but i bought a boost gauge and was wondering what vacum line i should connect it to. Thanks, Rob
Old Aug 6, 2008 | 08:12 AM
HKusp's Avatar
HKusp
It goes to the map sensor line actually. If you hook it to a vacuum line, it will read vacuum. You don't want that, you want boost. If you go to Diesel Manor's site, they have excellent instructions for putting in a 3 gauge pod, just read the part about the boost gauge map line splice and bam, you are there. It is by far the easiest of the three to install. Good luck.
Old Aug 6, 2008 | 08:21 AM
WHT00EX's Avatar
WHT00EX
Thank you very much! I'm gonna check that out now
Old Aug 6, 2008 | 08:39 AM
superduty4x4's Avatar
superduty4x4
Alternately if you are feeling like it, you can tap a fitting into the spyder and install it there, but it requires pulling the spyder off to keep from getting metal shavings in your motor. Mine's in the MAP hose- quick and easy install.
Old Aug 6, 2008 | 08:47 AM
danskool's Avatar
danskool
Go Bills !
Put your "T" here 3-Gauge Install Pictures
Here is the entire gauge install site Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Old Aug 6, 2008 | 10:24 AM
WHT00EX's Avatar
WHT00EX
Thanks again I just got it in
Old Aug 6, 2008 | 10:38 AM
03_PSD's Avatar
03_PSD
or while your in the modding mood, get the AIH delete with the booosht tap
Old Aug 6, 2008 | 01:33 PM
WHT00EX's Avatar
WHT00EX
Whats the AIH delete?
Old Aug 6, 2008 | 01:36 PM
HKusp's Avatar
HKusp
Auxillary Intake Heater. It is the the intake spider, and is a coil to warm the intake air when it is really cold outside.. Many people delete it because it may pose a restriction to smooth intake air.
