can I get a vin code decoded please?
This should help you decode everything http://www.fordification.net/tech/vin.htm
As far as which axle you have, it should be stamped on the housing in the bottom right corner next to the pumpkin. May take a wire brush and cleaner to see
A decoded VIN won't provide that information.
The VIN only provides the model, engine code, manufacturing plant, and consecutive unit number.
However, the warranty plate riveted to the rear face of the driver's door does provide the codes necessary for determining how the truck was originally delivered... unless the door has been swapped and the warranty plate wasn't transferred.
Dana 44 under the rear of a Ford truck, never as far as I know...https://en.wikipedia.org/wiki/Dana_44 But what do I know? lol
Here is ND's take on it from way back when. https://www.ford-trucks.com/forums/7...ml#post6514873
1959/67 F100's with 9" were not available with Limited Slip, 1968 was the first year.
Some 1963/66 F100's also have Dana 60.2 .. some 1966/68 F100's have Dana 60.3 .. both with Limited Slip, but neither is a Dana 60.
No 1966/77 Bronco had a Dana 44 rear axle.
Pic: 1977/79 F100/150 Dana 44-3 rear axle applications:
^ Safety Standard Certification Label ^
Production Date: 3/79
6,050 lbs. Gross Vehicle Weight Rating.
F15 = F150 2WD Pickup.
B = 300 1V I-6.
K = Kansas City MO Assembly Plant.
EJ1014 = 1979.
Warranty Plate riveted to the left door face below the latch has the TRANS, AXLE and etc. codes.
B = 300 1V I-6.
EJ1014 = 1979.
62-05ford
19
04-19-2014 10:59 AM
johnmel59
10-25-2013 12:47 PM
down2earth1928
30
08-13-2009 08:04 PM
