Leak at turbo pedastal - Help
I just developed a small oil leak under turbo on pedastal. Guessing ebp rod O-ring as oil is on pass. side of pedastal. I am also going to replace all o-rings while I have the turbo out & new cac boots & do the frx .Also gonna delete the ebpv and plug the port. Any advice or tips on the turbo removal would be appreciated as this will be my first time. Or if anybody has a link with pics that would be great. I have right at 99 k on truck so it's due for o-rings anyway.
Best advice I can give you after doing this several times is get yourself set up to be able to comfortably work and lift/lower the turbo into position. I built a top side creeper for the job, made it a lot easier. You have to be able to lower that 30 lb turbo into position while being careful not to push your pedestal o rings out of position while at the same time engaging the EBPV actuator, and laying on a padded, stationary surface makes it a lot easier. It is also a lot easier lining up the collector with a topside creeper. Lining up the collector is a lot easier if you get the manifold to up pipe bolts really loose. In order to access the passenger side manifold bolts the first time I pulled my wheel liner, the second time I just cut part of it away to get my socket in there.
And PB Blaster on the manifold bolts will help a lot.
If you have 1/4" extensions (long ones) it makes the job go easy. I always use a small electric impact driver or drill driver. That way I get all the nuts on the clamps loose and out of the way. Having done it enough times I can now have the turbo out in about 20-30 minutes. When you take it apart, look at how things are lined up. When you put it back together, line up the clamps so they are easy to get at. That will help in the long run.
Definitively loosen the up-pipe to manifold bolts! Very helpful in getting the collector off and back on!
What I did to help myself out on this portion of the install because it was such a PITA after I cleaned all the oil off of everything I took a couple dabs of gasket maker on the orings when I put them in place just to help insure they wouldnt move, and it worked flawlessly
teddyinastroker
11-28-2012 10:54 PM
Franko72
23
11-22-2012 01:17 PM
