Need help
Old May 12, 2012 | 11:57 AM
firefighter1992's Avatar
firefighter1992
Need help
Just installed new turbo and now this dang truck is running like a dodge... I have 4 different codes showing also, p0475, p1316, p0340, and p1210. What the heck is wrong???? it sounds and runs like some of the injectors are not workin...
Old May 12, 2012 | 01:12 PM
woodnthings's Avatar
woodnthings
P0475: Exhaust Pressure Control Valve Malfunction
P1316: Injector Circuit/IDM Codes Detected
P0340: CMP Sensor Circuit Malfunction
P1210: Injection Control Pressure Above Expected Level
My guess is you may have already had the P0475 and P0340 codes before starting. My other guess is you knocked one of the connectors loose at the top of the valve cover. Look to make sure they are seated properly.
Old May 13, 2012 | 10:06 AM
ToMang07's Avatar
ToMang07
Did you pull the valve covers in the process???
Sounds like a UVCH issue to me... the ones not working on the same side?
Old May 13, 2012 | 10:41 AM
firefighter1992
did not pull valve covers and what is uhvc? not sure which ones...
Old May 13, 2012 | 12:13 PM
smithrock's Avatar
smithrock
Under Valve Cover Harness- there is a connector there that could come loose. If so, the 50 cent mod might be in order. Do a search of 50 cent mod w pics.
Old May 14, 2012 | 09:13 AM
firefighter1992
still stumped
i did all the things u guys suggested and still no luck....
Old May 14, 2012 | 09:21 AM
woodnthings
Have you cleared the codes and rechecked them?
Old May 14, 2012 | 07:18 PM
F350-6's Avatar
F350-6
I'd forget the codes for now. What kind of turbo did you install? Do you have a boost gauge or way to monitor boost?
I'd double check for an exhaust leak either at the up pipes, or where the collector bolts on to the back of the turbo. If you don't line that collector up on the back of the turbo just right with the alignment dowel, you end up with a big leak that won't allow you to build boost.
Old Jun 4, 2012 | 12:42 PM
firefighter1992
thank you
thanks for the pointers, all is running fair now. the turbo still sounds like metal on metal though... puzzled.... i had a small leak on that back side and the biggest part of the codes was a bad alternator..
cwbyup2002
Nov 25, 2014 03:30 PM
bkuuz1
Dec 3, 2013 03:33 PM
nuke tech
Aug 8, 2013 09:05 PM
bkcowboss
Jul 6, 2009 11:47 AM
250sforme
Dec 4, 2006 11:24 AM
