oil leak again
Old May 3, 2007 | 06:30 PM
powerstroke1869's Avatar
powerstroke1869
oil leak again
alrite i posted a few days ago bout oil in my valley pan well i noticed that its right below the turbo and it drains out below my truck im wondering where you guys can point me to to get my turbo pedistal o-rings and possibly some instructions on how to do it thanks again
bobby
Old May 3, 2007 | 08:17 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
look on flebay, or the sponsors, and this might be you pedestal leaking, EBPV its a common problem , and look http://www.7point3.com/mods.aspx
you find a lot of good info there, just follow turbo removal,
Old May 3, 2007 | 08:34 PM
powerstroke1869
do i have to remove my turbo completely to change out my o-ring?
Old May 3, 2007 | 09:20 PM
jtharvey's Avatar
jtharvey
Look here for a place to buy the o-rings: http://www.itpdiesel.com/store.php?c...on=show_detail
Yes, the turbo does have to come completely off to replace the o-rings. It's not a hard job. Probably took me 1.5 hours the first time I did it. Now, I can have it out in just under 45 minutes. I would also suggest replacing the o-rings between the pedistal and the engine. Once the turbo is out, you've got access and it's only 4 bolts to remove the pedistal too. The same o-rings are used under the pedistal as used between it and the turbo. So, if you do the pedistal you'll need a total of 4 o-rings, or two of ITP's set.
Old May 3, 2007 | 10:23 PM
powerstroke1869
hey do you have directions to remove the turbo out>
Old May 3, 2007 | 10:36 PM
jtharvey's Avatar
jtharvey
Right here: https://www.ford-trucks.com/article/...tallation.html
Old May 3, 2007 | 10:51 PM
powerstroke1869
thanks for the reply ill have to give it a shot
Randy777
Jul 8, 2014 11:36 PM
MucksCo
32
Apr 26, 2012 09:47 PM
Gental Ben 2
Sep 26, 2010 06:30 AM
BENG0924
19
Feb 9, 2009 11:54 AM
97 RED PSD
Feb 19, 2008 08:43 PM
