WHAT THE HECK AM I DOING WRONG??????
Old Nov 20, 2012 | 03:01 PM
Franko72's Avatar
Franko72
Molon Labe
Ok, as some of you know I rebuilt my turbo last week. When I first installed it I had an oil leak on the pedestal.
Today I pulled the turbo replaced the o rings (old ones looked fine, no pinches) reinstalled turbo and it's still leaking oil from between the turbo and the pedestal.
I pulled and reinstalled the turbo 4 times today & still have the same leak! (not as bad as the first leak, but still dripping)
I even tried my spare pedestal, and same drip....drip....drip....drip from under the turbo.
I deleted the ebpv from one pedestal thinking the leak was coming from the rod, but after pulling the turbo, the only oil I can see is all over the top of the pedestal.
I torqued the turbo to 18ft lbs like the instructions say..
I'm about to go redneck and break out the RTV...
Old Nov 20, 2012 | 03:08 PM
cps's Avatar
cps
the hold down bolts should be 35-37ft lbs.
Old Nov 20, 2012 | 03:15 PM
BadDogKuzz's Avatar
BadDogKuzz
Frank it doesn't sound you are doing anything wrong. So it has me thinking are you sure it isn't leaking from between the turbo core (center section) and the compressor backing plate where it bolt to core. And you have the t oring (looks like a cross oring). Because if it leaked there it would run down right where the turbo bolts to pedestal. That is my guess???
If it wasn't the turbo base to pedestal orings. And RTV isn't going to work with pressurized oil.
Old Nov 20, 2012 | 03:33 PM
Franko72's Avatar
Franko72
Molon Labe
Where did you get that number? I'm afraid to over tighten the bolts being that they go into aluminum
I though so too Ed, so I pulled the turbo real easy and held it up, but there is no sign of oil coming from that area Plus it looks to me like a leak in that area would put the leak on the right (drivers side) of the turbo. From what I can see (and it's not easy to see in there with the spider installed) it's slowly running out of the left (pass side) of the turbo base. If that makes sense
Old Nov 20, 2012 | 03:43 PM
Bonanza35's Avatar
Bonanza35
You can call Clay, but the pedistal is 18 I believe and the two large bolts to the turbo are 35lbs. Other web sites also say this. Not sure thats your problem but 35# is correct. I have a small leak from time to time to I need to find, it started after turbo install. Can't see anything up top so think its turbo related.
Chet
BadDogKuzz's Avatar
BadDogKuzz
I do believe that to be correct too. I think that is Garrett or IH torque specs because if I recall I torqued mine to 35ft lbs. But that differents in torque specs it shouldn't leak even at 20ft lbs. If I reacll reading that 20ft lbs some have had to retorque turbo down the road and that was the only issue. But I could be wrong on what I read.
Old Nov 20, 2012 | 03:59 PM
Franko72's Avatar
Franko72
Molon Labe
Chet
You both are correct (ding ding ding) Just talked with Clay and he says 30-35 ft lbs is correct. Garret says it's ok,
Ford says 18ft lbs for some reason
Fingers crossed that this will fix the leak.
If your hunch is right about the "X" O ring Ed, I have my spare turbo standing by.
Thanks for the reply's guys
Old Nov 20, 2012 | 04:30 PM
nlemerise's Avatar
nlemerise
Man have I ever been there myself!
Old Nov 20, 2012 | 06:54 PM
Pitcrw6's Avatar
Pitcrw6
Did you get it fixed Frank?
Old Nov 20, 2012 | 07:01 PM
Robert6401's Avatar
Robert6401
Just want to let you know that I had almost the same exact call to clay a couple of weeks ago. 18 ft/lbs just didn't seem like enough to me.
Old Nov 20, 2012 | 07:13 PM
Franko72's Avatar
Franko72
Molon Labe
I gave up for today. I'll tackle it in the morning.
I felt the same, when torquing into aluminum, asking is better than a risk.
Old Nov 21, 2012 | 08:09 AM
SkySkiJason's Avatar
SkySkiJason
Good luck Brown. Fingers crossed!
Old Nov 21, 2012 | 09:07 AM
Tugly's Avatar
Tugly
O-ring seals on the pedestal shouldn't need that much torque to seal... something is up. Does anybody remember that spider with a bad casting and the boost leak was a bear to find?
You're there and you know what you've done. My list, if I was first approaching this problem:
  • Verify O-rings are the correct ones.
  • Inspect them with the strongest magnifying optics I can get my hands on, looking for issues on the sealing surfaces.
  • Inspect the tapered tube and all metal surfaces that touch the O-rings... using the same magnifying optics.
  • Ensure the suspect mating surfaces have no unevenness that can prevent a proper seat.
Old Nov 21, 2012 | 09:23 AM
Snowseeker's Avatar
Snowseeker
When I did all my stuff I noticed it takes some time to get the turbo to sit down flat on the pedestal. The turbo has to fit in the baby butt just right before it sits down on the pedestal just right.
I also went to 35ft/lbs on the turbo bolts.
If the turbo leaked on two different pedestals I would be looking into the turbo for the leak, either out of the turbo itself somewhere or where the turbo meets the pedestal. Makes sure the turbo surface is flat and there are no burrs stick up. Also make sure the o-ring surfaces on the turbo are perfect. Also like mentioned make sure you have the right o-rings in there. Skinny o-rings won't make the seal.
Old Nov 21, 2012 | 03:51 PM
Franko72's Avatar
Franko72
Molon Labe
UPDATE!
You are exactly right
After trying my spare turbo this morning and still having a leak a light bulb went off in my head. (yes it took 7 times pulling the turbo )
My baby's butt was a minute pinch higher than It should have been and was keeping the turbo from sitting 100% flat on the pedestal. Torquing to 35lbs wasn't enough to move the baby's butt down a hair.
I loosened all of the up pipe bolts & readjusted the baby's butt a "c" hair and no more leaks
On a good note, I can pull a turbo in just a few minutes now.
Thanks for everyone's help and suggestions
