sct vs edge
Old 06-03-2012, 05:36 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
its the Edge milage drafting looney tune
Old 06-04-2012, 12:05 AM
dhag911's Avatar
dhag911
dhag911 is offline
ok so after all the info I have been hearing and seeing on here. Im going to go with the SCT and get some custom tunes eventually just got to figure out whos to go with. I do have one last question. When I select the EGR off function is that pretty much the same as an EGR delete?
Thanks again guys still learning about this motor and this is def a good place to get the answers!
Old 06-04-2012, 10:35 AM
ooms221's Avatar
ooms221
ooms221 is offline
Where do you get the custom tunes for the SCT?
Old 06-04-2012, 05:53 PM
built tough's Avatar
built tough
built tough is offline
I have the edge and put it in for maybe 5 min and promply took it out the truck shifted like a absalute mule but a buddy of mine has the same one and loves it and went into the program and changed all the shift points you guys figure he will have the tranny issue or since he played with it a bit may be good sorry for the hijack
Old 06-04-2012, 07:33 PM
rhjj's Avatar
rhjj
rhjj is offline
My custom tunes are from Innovative Diesel. I have run extreme street over 90,000 miles no problem.
Old 06-04-2012, 07:39 PM
rhjj's Avatar
rhjj
rhjj is offline
Why some guys use Edge programmers kills me. The sct custom tunes also program the transmission. Do a search and you will verify this. If you want to guess on where you're transmission should shift, you better save some money for a rebuild.
Old 06-04-2012, 08:23 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
Innovative diesel & gearhead automotive preformance, are both excellent tune writers.
Old 06-04-2012, 09:01 PM
MurderMode's Avatar
MurderMode
MurderMode is offline
What kind of other mods do you recommend before going with a tune? I have a 4" straight pipe, EGR delete and a blue spring upgrade. Should I worry about head studs or anything else?
Old 06-04-2012, 09:13 PM
ooms221's Avatar
ooms221
ooms221 is offline
Are programs from Innovative diesel & gearhead automotive preformance priced pretty goid? And what's blue spring i see people talking about? Sorry to change the subject
Old 06-04-2012, 09:18 PM
Curt's05's Avatar
Curt's05
Curt's05 is offline
Wiser by FTE
Gauges for shure, including exhaust temp (egt), Studs for any tuning over 60-80 hp, just my .02
Old 06-04-2012, 09:49 PM
MurderMode's Avatar
MurderMode
The blue spring upgrade increases your fuel pressure and helps your injectors last longer. About 70 bucks for the kit and can be installed in your driveway. Worth every penny.
Ford Blue Spring Upgrade Kit
Old 06-05-2012, 07:39 AM
rnolloth's Avatar
rnolloth
rnolloth is offline
I'm another who will say stay away from the edge.I too have an sct my tunes are from Innovative as well.I run the extreme street all the time unless im towing.I've run it for about 40,000 miles not a single problem at all.Ialso have the tow tune with the exhaust brake, which i must say is amazing!!!! Innovative had great service and actually took the time to ask what i was looking for out of my truck.Depending on my gear ratio tire size and what i wanted to do with the truck.And actually wrote the tunes from there.Not just a set of tunes that wont apply to every truck. Or the owners wants or needs for there particular application.
  #28
Old 06-08-2012, 01:15 AM
dhag911's Avatar
dhag911
dhag911 is offline
does any one know about the EGR off function on the SCT. Does it act like an EGR delete?
  #29
Old 06-08-2012, 06:20 AM
tex25025's Avatar
tex25025
tex25025 is offline
It's an electronic version of the EGR delete. It does allow you to remove the tune and everything be legal on the truck, unlike the delete which is pretty well done with once you delete the EGR.
If you just have to do try to take the EGR out of the loop, I would do it electronically, at least you can reverse it on a moments notice.
  #30
Old 06-08-2012, 07:51 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
05 f250 6 inch lift is offline
I had a bulldog programmer an the bullydog outlook monitor. It was in my truck when I bought it. When I had it on performance mod an was in the go pedal pretty good an trans shifted I thought it was goin to rip the trans out of my truck because it shifted so hard. Made good power but also kelp EGT kinda high to.
When I done my studs an HG I pulled all that out an got a SCT livewire used from a guy on here. I love the SCT tuner ALOT better. It's canned tunes don't make as much power as the bullydog did but my EGT are alot lower with the SCT.
Soon to get custom tunes after I get my gauges. IMO I would get a SCT tuner, scangauge, an a few pillar pod gauges an I think that would still be cheaper than the edge cts. An you would be able to access more info from your truck.
043506.06speed
1999 to 2016 Super Duty
05-08-2014 01:41 PM
ndlawrence
06-17-2013 12:22 PM
uuhiteboy
02-18-2013 12:50 AM
lewis racing
08-19-2010 06:04 PM
Baddfx4
09-06-2007 01:13 PM
Quick Reply: sct vs edge
