Vacuum Issue, maybe?
#31
#32
That plastic vac line is real brittle, esp. what's been under a hot/cold hood for years. Either patch in regular rubber vac hose or splice with heat shrink tubing.
You could remove the booster, take the grommet out of the hole for the check valve, and just see if that cap falls out. Otherwise, maybe a shop vac...
#33
Yeah. Looks like I'll pull the booster and shake it around to get it to fall near the hole.
#34
#35
#36
#37
I think I've got this one in the books. We'll see though.
For now I just wrapped the AC hard line with electric tape and it seems to be holding fine. I got the plug out that I dropped in the booster. Pulled the booster and wiggled it around upside down til I could grab the plug with some pliers.
And the check valve and its grommet were most definitely bad. I couldn't build any vacuum into the booster with my gauge through either of them. New parts from Ford and voila I can build up vacuum in the booster and hold it all day long. Now hopefully that's it for this issue for a while.
Thanks for all the help.
Power Brake Booster Check Valve - DOAZ 2365 A
" " " " " Grommet - C9AZ 2B176 B
86f350
27
11-27-2014 07:09 AM
