New problems related to the GEM?
2000 F350 PSD 6 speed 2wd
OK, I have had a recurring issue with water getting into the GEM under the dash (which is a whole other issue). Previously, I could let it dry out and all would be good. This last time, I took out the GEM (big pain in the butt) and all looked and worked fine when it all dried out.
However, this time, literally overnight, the speedo stopped working, the air bag light stays on and the blower motor doesn't work. I read another post on the FTE that said the speedo is not related to the GEM. I changed out the VSS and the speedo still does not work. All of the other gauges and electricals work fine.
Does anyone have an idea as to what is going on? I'd rather not have to shell out the $$ by taking in to the dealer if I don't have to.
Thanks!!
Mike
Thanks!!
Mike
Air bag, or ABS light? If the speedo stops working, the ABS will complain, not the Air-bag.
As for the blower motor, that's strange, do you have climate control, or basic heater/AC controls?
I'd start checking grounds, the blower and the speedo/ABS aren't related to the GEM in anyway, I don't think.
Mike
Mike
Do you have the key-switch in the dash to turn off the passenger-side airbag? If so, does the light come on in the switch when you turn the key to ON?
I'll try to remember to take a look in my service manual's EVTM when I get home tonight and see if there is anything in these systems that's related.
Thanks. I'm almost thinking that the fuse block might have issues after this last bath it took. The symptoms were different than before and two of the 3 issues share a common fuse in the block. Let me know if you might htink it is something different.
Mike
Thanks
Just an update: I ended up taking it in to the dealer to get it figured out. As it turns out, all 3 issues were due to the fuse block AND GEM module problems. They replaced both and all is good now.
By the way, they found out that the particular GEM is on NATIONWIDE backorder until November. We replaced mine with a salvaged one.
'83f3fiddy
02-25-2011 11:41 PM
kevin22602
Electrical Systems/Wiring
03-23-2007 06:21 PM
coollooking96F350
04-11-2005 07:04 PM
