Sponsored by: Real Truck
Electrical issues
Old Jul 5, 2012 | 09:41 AM
Texas H.M.'s Avatar
Texas H.M.
Electrical issues
2000 F350 PSD 6 speed 2wd
Background: I have had water issues with the GEM. Once it dried out, all was normal until this last time.
This last time however, after it dried out, the speedo and A/C blower motor (manual HVAC) were not working and the air bag light stays on. I checked all of the grounds and all were good. I jumped the blower direct to the battery and it works. I checked all of the relays and fuses - all work good. I thought that it might be the fuse block, but I still have power on the hot side of the fuse. Cruise control still works and I tried replacing the VSS with no change. All other functions still work as normal.
I'm stumped...what else could it be?
Old Jul 5, 2012 | 09:44 AM
woodnthings's Avatar
woodnthings
You may need to take it apart and look it over. Sounds like it has issues now. Also it sounds like it needs to be better protected and the windshield needs sealed or replaced.
Old Jul 5, 2012 | 01:09 PM
Texas H.M.'s Avatar
Texas H.M.
I have had the fuse block out twice and have found nothing wrong with it (externally, that is). I tried to open it and found that it wasn't made to open back up.
No doubt that the leak is an issue and will be fixed a some point. I just need to find out what is going on with the A/C, speedo, and air bag.
Old Jul 6, 2012 | 09:28 AM
Texas H.M.'s Avatar
Texas H.M.
Anyone else have any ideas?
leardvr
Feb 9, 2018 01:49 PM
FordLou
1997 - 2003 F150
30
Dec 6, 2014 12:14 PM
Texas H.M.
Aug 8, 2012 09:52 AM
keystone
Jul 5, 2005 10:23 PM
yosemite
1978 - 1996 Big Bronco
Jun 30, 2003 01:59 PM
