73 360 valve lash settings
Old 03-30-2012, 12:29 PM
jnf425's Avatar
jnf425
jnf425 is offline
hello! I am hoping someone knows here, im needing the correct gap measurements for the intake and exhaust valves on a 73 f100 with the 360. Ive gotten conflicting info from other places, differing measurements and do both intake and exhaust when hot or do the intake when cold and the exhaust when hot. So, im not sure which is right Appreciate any help, Thanks!!
Old 03-30-2012, 12:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
This will probably add to your conflicting info.
360's have hydraulic lifters and are non-adjustable. The rocker arms have no provision for any kind of adjustment.
Here's a picture of the FE (360/390) rocker arms.
Why are you needing to adjust them?
Old 03-30-2012, 12:49 PM
jnf425's Avatar
jnf425
jnf425 is offline
It was my understanding that you were to bleed the lifters and check the tolerances, and use the different length pushrods available to give you the desired gap.
Old 03-30-2012, 01:01 PM
OldStyle's Avatar
OldStyle
OldStyle is offline
Rusty Roller
Collapsed lifter gap: Allowable= 0.119 - 0.219 Desired= 0.144- 0.184
Old 03-30-2012, 01:02 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Oh, okay. Let me dig out my shop manual and see what it gives in the way of specs.
I'll get back with you.
BTW welcome to FTE.
Old 03-30-2012, 01:03 PM
Blown 331's Avatar
Blown 331
Blown 331 is offline
Are you building or modifiing the engine? You shouldn't need to mess with it as part of normal maintenace.
Old 03-30-2012, 01:07 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Dang I'm gettin' slow, Oldstyle beat me with how to check.
According to the FACTORY '73 shop manual, the collapsed tappet clearance for the 360/390 is:
Allowable: 0.119"-0.219"
Desired: 0.119"-0.169"
Blown331 is correct though, usually this is only required after some major work, not as part of routine maintenance.
Old 03-30-2012, 01:16 PM
jnf425's Avatar
jnf425
jnf425 is offline
@old style, thank you very much! Exactly what I needed!
@mikeO thanks for the welcome!
@blown 331, got this engine from a guy that had a shop only rebulit the lower end and used all the old valvetrain components, currently have a cold lifter tap so im going to be replacing lifters for sure, and see what else on the teardown
ole72f100
10-20-2010 09:49 PM
1969furd
04-20-2010 11:59 PM
agitator_k
01-19-2003 12:38 AM
gtex
06-23-2002 08:51 PM
guyasmith
02-13-2001 10:10 AM
Quick Reply: 73 360 valve lash settings
