valves
Old Apr 20, 2010 | 11:31 PM
1969furd's Avatar
1969furd
valves
i have a freind who has a 1964 f100 r Ranger with a 360 v8. His mecahinc says the number 7 valve needs adjusted, how is this done. I am not sure if it is an intake or exhaust, how is this done?
Old Apr 20, 2010 | 11:59 PM
garbz2's Avatar
garbz2
Ok i will bite.
The 360 is a replacement engine (not stock in 64 Rangers) only in 68 to 76 ford trucks and typically has hydraulic lifters requiring no lash adjustment. Clearance is obtained by using differing length push rods. High performance FEs use mechanical cams and adjustable rockers and need to be manually adjusted with a feeler gauge. a cold 390 PI is .028 along with the 406 and hot is .025.
JIC you have 292 the rockers are manual adjustment as they use mushroom flat tappets
Intake and exhaust lash is with the engine hot .018 clearance between the valve head and the rocker face.
Garbz
hayden01
Jul 26, 2016 03:18 PM
NewToDiesels
Aug 28, 2011 05:06 AM
Regg_65
Jan 19, 2009 07:32 PM
rmalottwtes30
Apr 27, 2008 10:53 PM
reifwj
29
Apr 22, 2008 09:13 AM
