baldwin BF7725 and hutch/harpoon mod
Old 03-20-2012, 04:43 PM
PEI's Avatar
PEI
PEI is offline
Ordered in a baldwin bf7725 filter, plan on doing the hutch/harpoon tomorrow. BUT looking at it, the opening is 5/16 and the hose I have is 3/8. VERY loose.. Will this clamp down enough or is there a 3/8 version out there?
Thanks!
Old 03-20-2012, 05:17 PM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
Others have been successful, but mine tended to weep. Plus I did not like the idea of installing a restriction in a 3/8 system. I also tried a Hebmueller variant with brass inserts so I could torque the clamps a bit, but it still wept. I ended up using $4 Fram G3s, at least it is still clear(ish) and 3/8.
If someone has a pn for something like the Baldwin in 3/8, I'd looove to see it.
Old 03-20-2012, 05:20 PM
PEI's Avatar
PEI
PEI is offline
Thanks
Will install this as a temp solution tomorrow then pick up a fram g3 the following day. The place I got this at is a truck store and has a large selection of fram stuff.
Thanks
Old 03-20-2012, 06:28 PM
Poolguy601's Avatar
Poolguy601
Poolguy601 is offline
Hay PEI. What part of the island do you live.
Old 03-20-2012, 06:40 PM
PEI's Avatar
PEI
PEI is offline
Cornwall, about 5 minutes outside of Charlottetown.
Been here before?
Jason
Old 03-20-2012, 09:49 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Baldwin makes several in 3/8", but all are metal.
BF1052
BF1173
BF836
If see-through is mandatory, you're SOL in Baldwin.
Pop
Old 03-20-2012, 10:00 PM
PEI's Avatar
PEI
PEI is offline
BF1052
BF1173
BF836
Pop
Thanks!
Not mandatory, just be nice to see when it starts getting dirty. Not sure how clean the interior of my tank is. Guess I will find out when looking at the pickup filter.....
Old 03-21-2012, 04:50 AM
Poolguy601's Avatar
Poolguy601
Been here before?
Jason
Been there before. Way back when there was a ferry and now a bridge from the main land. My freinds family owned a hotel on the North side called the Blue Fin. His mom lived in the red house on the point.
Old 03-21-2012, 06:58 AM
PEI's Avatar
PEI
PEI is offline
I was up that direction last summer for a drive..
Old 03-21-2012, 07:04 AM
trekbasso's Avatar
trekbasso
trekbasso is offline
Thanks!
I used a NAPA Gold 3003 when I did mine a couple of weeks ago. So far it seems fine. 3/8 lines and see though.
Old 03-21-2012, 07:06 AM
PEI's Avatar
PEI
PEI is offline
Thanks!
Going to start on it within the next few minutes...
Old 03-21-2012, 07:47 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
w/out googling the baldwin, can you install a 5/16npt with a 3/8 barb?
Old 03-21-2012, 07:25 PM
dn29626's Avatar
dn29626
dn29626 is offline
...I did not like the idea of installing a restriction in a 3/8 system...
The fuel pump is only 5/16, so where is the restriction?
I have had those fram G filters collapse and starve my truck.
My suggestion is to use a (WIX-rated for mercedes diesel fuel systems) 33007 5/16 just before the fuel pump. A few inches of 5/16 between the filter and the pump. Use a barb and reduce the 3/8 to 5/16 for the infeed of the filter.
Several of us use a similar set-up.
alienbogey
08-21-2013 12:32 PM
pctjk
15
09-05-2007 04:01 PM
bigdawg460
07-10-2006 09:29 PM
Quick Reply: baldwin BF7725 and hutch/harpoon mod
