Help me find waterpump, flathead 6
Old 02-21-2012, 08:31 AM
Cody_1948's Avatar
Cody_1948
Cody_1948 is offline
Guys, along with getting my flathead motor I soon to find out that the waterpump is shot, I called a few auto shops and also a early ford parts shop, anyways early ford shop called and told me didnt have any but found one for $175 +$50.00 for a core charge, this $200 waterpump is a reman... Anyone have one that works ? I could maybe buy one cheaper then $175, or should I try and fix my up ?? But its a 49 ford f1 flathead 6
~Cody
Old 02-21-2012, 11:36 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Check out rockauto.com - they have a rebuild and return program that is less costly. Your old WP will get a trip to Philly to a reman shop that only deals with resellers (you can't go direct to them) and then should arrive back at your house ready for install.
DW
Old 02-21-2012, 01:26 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is online now
Received 2,059 Likes on 804 Posts
Cody,
I just checked out Rock, just like DW suggested. It's probably the cheapest you're going to find. You can also check Job Lot Auto in NY, they list pumps for earlier Ford 6 cylinders, they might also car your. They also list rebuild kits.
If your pump is in pretty good condition but has worn bushing and seals you could piece a kit together if you have a place local that sells bearings. My neighbor has rebuilt pumps on his flathead V8s by buying parts from a local bearing distributor, Bearings Inc.
pezsox
12-21-2018 04:14 PM
acfd
17
03-21-2016 05:38 PM
c249a
21
06-09-2015 06:11 PM
grandpas 56
16
02-02-2009 05:39 PM
jack71
09-07-2005 08:42 PM
Quick Reply: Help me find waterpump, flathead 6
