1948 Ford F1 Flathead 226 Rebuild Recomomendations ??
I am finally getting around to having my engine machined and rebuilt for my truck. I was wondering if any of you suggest a company that you have had great service and good prices from to buy the rebuild kits, pistons, rings, etc... I have looked at Egge, and Kantner so far. I finally got my list back from the engine rebuilder and pretty much everything out there is available. So far the only issue I am having is the Oil Pump rebuild kit, I haven't been able to locate that. Any suggestions would be appreciated. thanks
I wouldn't necessarily buy a "kit", I would select top-quality parts from known players. Pistons from Egge, rings from Hastings, bearings from Clevite or Federal, gaskets by FelPro or Best.
Have your machinist inspect the oil pump carefully. Unless it's had sand run thru it, it is likely in good enough shape. Sometimes the end cover just needs surfacing to remove grooves. If the shaft is wobbly in the body, it will need bushing, and a kit won't fix that anyway.
53 merc m350
11-23-2016 11:39 PM
