C6 modulator on C4???
Would a vacuum modulator from a C6 fit a C4 transmission??
I am looking at the possiblity of adapting small diesel engine to a vehicle with a C4 trans. The standard modulator arrangement doesn't work because diesels don't make vacuum. There are mechanical modulators for the C6, they use a cable connected to the throttle lever to move the modulator valve in/out to change pressure and shift points. PATC has one, and supposedly diesel powered airport Ground Service Equipment made by Tug or Yale with the C6 trans also have mechanical modulators.
Same questions different way. Were there diesel powered industrial tractors, lift trucks, or mowers, etc. that use the C4 transmission?? Manufacturer and part number??
Full manual valve body likely would also work around the no vacuum problem, but the wife (aka the BOSS) will also be driving the conversion, and I am sure she would not want to shift gears.
Piper106
Piper106
Received 3,108 Likes
on
william16339
10-21-2016 10:17 AM
genscripter
09-13-2014 06:23 PM
kermit
06-17-2005 03:26 PM
ranger pat
06-19-2001 06:44 PM
400, c4, c6, cable, conversion, ford, industrial, mechanical, modulator, modulators, motor, shift, transmission, tubing, yblock
