C6 vacuum modulator
Old Jun 17, 2005 | 02:08 PM
kermit's Avatar
kermit
C6 vacuum modulator
just a question, havent done a vacuum modulator in a while, and havent done one on a C6 ever, but is there supposed to be a little metal piece inside the modulator?? when i took it off of the truck, a little metal piece came out of the modulator, and i need to know if it is supposed to be replaced
thanks,
jamie
Old Jun 17, 2005 | 03:05 PM
1973F100's Avatar
1973F100
If you are talking about actuator rod (about 1.5" long and about the diameter of a pencil lead), yes, it must be replaced (actually reused) or the modulator won't do anything. Put a little vaseline on it to hold it in your new modulator as you install it.
Good luck...
Old Jun 17, 2005 | 03:26 PM
kermit's Avatar
kermit
actually, mine came out in 2 pieces, so i guess i get to find a different one, that is actually still one piece.
thanks
