lcd brightness
lcd brightness
is there anyway to adjust the brightness of the lcd info and nav displays. I know the light dimmer adjusts it but not in relation to the gauges, if I turn the screens down enough I can barely read the speedometer. is there a way to adjust just the screens?
thanks in advance
thanks in advance
okay well played around some today and found you can adjust the nav display a little bit throught he settings menu, only a plus or minus of defaults. Havent driven tonight so cant say for sure if it helps or not. will probably have to go with 2nd s suggestion of the blank screen for the other screen which is fine since I can never figure out what to put there anyway.
