Waterpump problem??
Waterpump problem??
im just making 100% sure for reassurance if antifreeze is leaking out from behind the pulley that holds the clutch fan which is the water pump means i need to replace the water pump correct? it is also making and odd random knocking sound not that of a piston or rod the knocks are random hopefully not a broken timing chain whipping around in there i have a 1990 ford f250 HD with a 460 4x4 manual
well it was definately the water pump and it was leaking from behind the spindle that holds the fan and spool so the bearings went bad but when i went to remove the pump we found out that it was JB welded to the timing chain housing and that cracked so i have to replace that too its $120 i dont have and not a whole lot of fun
lildreamer67
03-24-2013 10:01 AM
Galendor
36
09-17-2011 01:00 AM
hollywood4
11-01-2006 05:31 PM
