Radiator Support '49
Old 12-08-2011, 08:02 AM
john fin's Avatar
john fin
john fin is offline
Why are there 4 holes on the lower frame for the radiator support. The 2 closest to the engine are for the radiator support, right?
Old 12-08-2011, 08:05 AM
Doc's Avatar
Doc
Doc is offline
The 2 closest to the engine were for the flathead 8. The 2 farthest from the engine were for the flathead 6 which was a longer engine.
Old 12-09-2011, 12:56 AM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
There's also a second set of holes on each inner fender to accomodate the different positions of the radiator support. The hood air shields were also different in size and positioning for the two engines.
Old 12-09-2011, 11:48 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,469 Likes on 1,408 Posts
Don't forget the two little squarish-shaped fillers pieces on either side of the radiator, at the top of the support next to the inner fender aprons. Those were different, too.
Old 12-10-2011, 12:59 AM
51PanelMan's Avatar
51PanelMan
Wayne,
Do you have a set of both to measure? I'm curious as to the size for each to compare to what I have. I need to add them to my 52.
Thanks.
Old 12-10-2011, 10:08 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Originally Posted by 51PanelMan
Wayne,
Thanks.
I suppose I do. (still working on the first cup of coffee, had to think for a second) I have two 6 cylinder sets from the F6's, and a v8 pair on the Merc. I'll have to do some research on that and get back to you. My guess is that they're almost identical, with the 6's being slightly narrower. Ford parts catalog shows 2 different part numbers.
Old 12-10-2011, 11:47 AM
bobj49f2's Avatar
bobj49f2
bobj49f2 is online now
Received 2,121 Likes on 821 Posts
One more six vs. eight radiator location, the hood panel, above the radiator is different to the two engines. The V8 is wider and is located closer to the cab.
Old 12-10-2011, 08:37 PM
john fin's Avatar
john fin
john fin is offline
filler pieces
52 merc , Do you have a pic of those filler pieces?
Old 12-10-2011, 08:42 PM
john fin's Avatar
john fin
john fin is offline
deflector
In the parts book, pn 8105, deflector is only listed for 53', dont see any for '49.
Old 12-10-2011, 09:23 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
I'm going to try to get to the shop on Sunday. I've got to get some pics of a lot of things.
The deflectors in question here are 7HC 8104/8105 RH and LH for the 6 cylinder trucks 48-52, 7RC 8104/8105 same application for V8 trucks.
Old 12-10-2011, 09:56 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
Jeff and Nicolle is offline
I have the '49 F3 Flat Six parts. I can take pics and or measurements. If ya want...
Old 12-13-2011, 12:30 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Here's a link to my new thread answering all of your questions.
https://www.ford-trucks.com/forums/1...l#post11147443
NashvegasMatt
01-29-2017 05:14 AM
Jeff and Nicolle
12-22-2010 11:10 PM
panningbros
02-16-2010 07:57 PM
52'F-3
05-08-2007 03:35 PM
frankydabull
1947 and Older Ford Trucks
03-08-2004 06:14 PM
Quick Reply: Radiator Support '49
