Howdy, I have had to replace solenoids (several so far) and it is getting old. Is there anything that could be repeadedly causing them to go bad. I know it is kind of a broad question, but send me in the right direction or tell me what else you need to know. I appreciate all the input,
A starter in it's way out can destroy solenoids. As can corroded/ bad battery and starter cables.
Josh
Ditto. I had a starter that worked and sounded ok but was pulling so much current I fried three solenoids in a row. New starter fixed no dying solenoid problem.
Got a way to measure the inrush current on your starter? Current gets too high it welds the contacts together or arc-pits the contacts so much the make poor contact.
Thank ya'll all very much. I will look into these things, the other thing with it and idk if this makes it more specific. If i start it up and drive down the stree maybe 2 miles im good but once I hit the highway at increase speeds and or distances is when it goes toast. Again Thank ya'll
