help
Old Jan 18, 2011 | 07:22 PM
77f250400's Avatar
77f250400
help
Hey guys my truck has been sitting with out a starter so I put one in and when I turn the key to start it and the starter makes a clunk but if I try to start off the silanoid it turns over fine I'm lost were should I be looking thanks
Old Jan 18, 2011 | 07:30 PM
supercabfreak's Avatar
supercabfreak
posibly a starter cable or a bad conection on either end if it
Old Jan 18, 2011 | 07:56 PM
77f250400's Avatar
77f250400
Thanks that's what ill do first thing in the am
Old Jan 18, 2011 | 09:49 PM
Riderman's Avatar
Riderman
I think you just answered your own question. If it starts by jumping\bypassing the solenoid, that is your issue. The "clunk", I believe is from the solenoid, that tells me the primary wiring to the solenoid is correct. The solenoid is not connecting the voltage/current to the starter from the battery. I'd replace the solenoid, and your battery cables probably need replacing as well due to age.
Old Jan 20, 2011 | 12:50 PM
77f250400's Avatar
77f250400
Hey guys riderman its the starter clunking when I turn key if I try the key 3.or more times it starts fine then I turn it off and try again and clunk
Old Jan 20, 2011 | 02:34 PM
MikePacey's Avatar
MikePacey
I've had this problem mulitipule times with my dents. Take some needle nose pliers and crimp the postive connection a bit. So its hard to get on. that should fix it. if not just spend the 14 dollars at advance auto parts for a new solienoid. also look at were the postive wire and the starter wire bolt to it. is it rusty or corrorded? take some sand paper to it if it is.
Old Jan 20, 2011 | 06:10 PM
77f250400's Avatar
77f250400
Thanks ill try that I've hade the dent for 6 years with no wiring harness for 5 and now I'm just about to get it on the road
jhoopman86
1978 - 1996 Big Bronco
Aug 4, 2010 09:30 AM
ridecolby
Aug 11, 2009 07:51 PM
inline6 Red Neck
Oct 12, 2006 04:56 AM
patmorrison
13
Feb 27, 2004 03:20 PM
Crumm
31
Nov 21, 2003 10:22 AM
