Drive's Side Power Window...grrr
Old 11-05-2011, 09:45 AM
VH_Girl's Avatar
VH_Girl
VH_Girl is offline
Question Drive's Side Power Window...grrr
When I first got my F250 back in '08 I noticed that everytime you held in BOTH buttons to operate both the driver's and passenger's window, the light for door(s) ajar would come on and make this annoying long beeping sound until I let go of the button (this does NOT happen on my F350 -- same year vehicle). Now I notice that when I press AUTO for the driver's window and let go, the window does go down but when it gets about 3/4 of the way open, it slows down tremendously. I'm thinking the motor is dying, as this happened on my F350 a few years back (though I never had a gauge light come on or any beeping). The window went down and wouldn't close ~ and it was freakin' below freezing that day. Grrr...
Should I assume the motor is on its way out, or is there something else it could be?
Old 11-05-2011, 11:02 AM
VH_Girl's Avatar
VH_Girl
VH_Girl is offline
To the individual stalking me on this site (and you KNOW who you are), get over yourself.
Old 11-05-2011, 12:04 PM
SARDiverDan's Avatar
SARDiverDan
SARDiverDan is online now
Mine is doing the same thing but only in the morning when it’s cooler outside. Once it warms up the window works fine; however, in the morning I need to hold the button down until the window opens all the way. I am sure with my luck that the widow will no longer function when I need it the most. Just another item on the “list” of things to work on.
Old 11-05-2011, 12:28 PM
tdpower's Avatar
tdpower
tdpower is offline
Try some silicon spray lubricant on the window rails.
Old 11-05-2011, 04:31 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
Or maybe Christine, pop the covers to expose the electrical connections at the switches ,and clean the contacts/surfaces.
Old 11-05-2011, 08:42 PM
Superduty ROCKS's Avatar
Superduty ROCKS
Superduty ROCKS is offline
x2 on the silicone spray.
Old 11-05-2011, 08:45 PM
VH_Girl's Avatar
VH_Girl
VH_Girl is offline
I will give the silicone spray a try! Thank you guys for your suggestions. Much appreciated!
Old 11-05-2011, 11:46 PM
kawcrasher's Avatar
kawcrasher
kawcrasher is offline
The door ajar light sounds like a ground problem with both buttons down.
I had the slow window problem and silicone on tracks solved it. I though the motor was just real weak until I rolled down in the rain one day and it worked fine.
Old 11-06-2011, 01:06 AM
4inchlovin's Avatar
4inchlovin
4inchlovin is offline
Heres a link to my window motor install thread... But you can also use it just to get the door panel off and try a good molly grease on the metal tracks along with the silicone spray in the window tracks...
https://www.ford-trucks.com/forums/9...or-w-pics.html
Or if you do need to replace the motor.
Old 11-06-2011, 04:35 AM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Mine does the same thing so I'll have try what was suggested above. Thanks
Old 11-06-2011, 06:41 AM
John7894's Avatar
John7894
John7894 is offline
Silicone sparay the felt guides, but the metal rails in the door need to be cleaned with parts cleaner then greased real good too. If that doesn't do the trick, then look into cleaning the window switch contacts and then the motor.
88 Bronco
1983 - 2012 Ranger & B-Series
04-30-2008 10:42 AM
four4x4fords
1999 to 2016 Super Duty
18
03-03-2008 01:09 AM
00f250sd
04-23-2006 09:29 PM
kilika77
1997 - 2003 F150
11-12-2005 09:21 PM
fordtrkpuller
03-07-2005 09:35 PM
Quick Reply: Drive's Side Power Window...grrr
