Need help is it the Starter?
Old 11-04-2011, 07:19 PM
Vegas123's Avatar
Vegas123
Vegas123 is offline
Hi Everyone,
Wondering if anyone would happen to know what may be the answer to the following problem. There is a 1950 F1 that I am looking to buy. The only problem I have noticed so far is that when the starter is engaged and just before the truck turns over a large sound (sounds like a hammer hitting metal) comes from the starter area of the truck. "bong" type sound. Engine is an 8 BA on.
I am not sure how these starters operate. When engaged do they have a piston or shaft that enters the fly-wheel and then turns in order to turn the engine over.
I talked to a mechanic and he thinks the starter may need to be shimmed.
I am not mechanic but I would think if it was the correct starter for the correct engine this should not be a problem. Has anyone experianced or observed this same problem?
Thanks for your time.
Old 11-04-2011, 07:46 PM
Tyler S's Avatar
Tyler S
Tyler S is offline
I am no help at all, but I have a pretty funny/embarrassing story about my starter...or not about my starter...
I thought I had a starter problem a few days ago. I redid my brakes and so I brought the truck down off the stands and was gonna test drive it. I got NOTHING when I tried to turn the truck over. Not a click, not a grind, nothing. I tried jumping the battery and still got nothing. I was looking at my start solenoid and relay etc. Looking at the starter. Etc, etc, etc. I was at a loss. After about an hour of this I was sitting in the cab with my chin on my chest wondering what the heck was going on. That was when I looked at the shifter and I had left the transmission in DRIVE to test the brakes up on the stands...I put it back in park and--amazingly--she turned right over.
Does that help you any?
Tyler
Old 11-04-2011, 09:13 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,469 Likes on 1,408 Posts
Originally Posted by Vegas123
Hi Everyone,
I'm guessing your mechanic is a Chevy guy.
I'm not the flathead starter expert here, someone brighter than me on that subject will no doubt be along shortly. But I'm pretty sure shimming is not going to be the answer. That was a GM fix for their poor block machining capabilities. Since the Flathead starter, as with most Ford engines, bolts to the bellhousing, it has a much more definite clearance spec between it and the flywheel.
You're correct in your basic understanding of how the starter works. Applying electricity to the starter spins a bendix which engages a small gear on the starter motor against the ring gear on the flywheel, then spins the engine. It's possible you have worn components causing strange noises to emanate from the area. But if it works and spins and starts the engine, it may not be a big deal, other than the strange noise itself. If that's the worse thing you can find wrong and like the truck overall, I'd say buy it.
Old 11-04-2011, 09:29 PM
Vegas123's Avatar
Vegas123
Vegas123 is offline
Thanks for your help.
Old blue is coming home.
I just need to figure out why its making this noise.
The truck starts fine.
Old 11-04-2011, 09:31 PM
Tyler S's Avatar
Tyler S
Tyler S is offline
NICE!!!! You bought it?!?!?! I have had mine for a couple of months and I am having fun with it...
t
Old 11-04-2011, 10:33 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
There's a spring inside the starter that pushed and recoils the gear on the starter that gets the flywheel going. The spring may be wearing out. It's an easy and cheap fix.
When you have the truck home, call me and I'll put you in touch with a guy that can fix it.
Old 11-05-2011, 12:13 AM
DumbLuck's Avatar
DumbLuck
DumbLuck is offline
A BONG type sound? Easy! Someone used a door bell button to replace the starter button. Just swap it back to an OEM starter button to cure it.
Old 11-05-2011, 10:57 AM
Vegas123's Avatar
Vegas123
Vegas123 is offline
Too Funny!
I wish it was that easy.
Thanks 51 Panel Man. I will be stopping by your place once I get Old Blue home.
I will post pics as soon as he gets here.
Open to hear other possible diagnosis of the problem.
Old 11-05-2011, 11:09 AM
51PanelMan's Avatar
51PanelMan
I thought that you're not getting it until early March? I guess plans changed. They guy must have needed the money sooner.
I'll be home most of the weekend working in the garage if you want to swing by. Call me first to make sure I'm not running an errand.
WaveyDavey1980
04-18-2019 09:31 PM
jgurland
03-30-2009 10:08 PM
mnbf
Bronco II
11-02-2005 07:28 PM
sdetweil
09-08-2004 10:03 AM
Frank Lang
04-04-2004 08:55 PM
Quick Reply: Need help is it the Starter?
