'53 Flathead - Help with a starting problem?
Old Mar 29, 2009 | 08:51 PM
jgurland's Avatar
jgurland
Hey, everyone. I'm hoping to get some help with a starting problem I'm having with my '53 F-100. It's running a stock flathead and I started having a problem a few months ago.
After driving for a while I came home and parked the truck. Several hours later I tried to start it again and all I got was a thud. Wouldn't turn over, just a thud. I sat and stared at the steering wheel for a few minutes (as I tend to do when confused) and tried it again. Still just a thud. About 2 hours later I wanted to listen to the "thud" sound again (so I could come to FTE and describe it accurately) and hit the starter button - but this time it started right up.
Next day I went back out and it started on the first try. Drove out to run an errand and after about 1/2 an hour I got the thud again.
Based on this limited description, what should I check first? Solenoid? Starter? Ground connections?
Old Mar 30, 2009 | 12:40 PM
Julies Cool F1's Avatar
Julies Cool F1
It sounds like your starter might be getting close to needing some work - might be affected by engine heat, or your battery isn't getting enough juice to charge it to turn the starter.
I'll bump this back up so the flathead guys like Ross (Albuq F1) can take a better look at it.
Old Mar 30, 2009 | 07:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1
At the front end of your starter, is there a bracket that goes from the starter thru-bolt to the oil pan rail? It is often tossed away. It supports the front end of the starter and maintains alignment.
The Thud sounds like the starter drive is not engaging the flywheel ring, or like Julie says, the starter itself is starting to die. Worn brushes may be at play here.
Are you running at 6 or 12v?
Old Mar 30, 2009 | 10:08 PM
denverslim's Avatar
denverslim
It's the "thud" part of this that has ME confused.
Every starter that I've had go baddo to brushes or armature usually whines or buzzes.
I like Ross' idea of misalignment though. Maybe just the bolts are loose causing the starter to hang down some, and the starter gear binds up in the flywheel.
Get back to us on the "thud", will ya?
