Front end question-Solved
Old 10-08-2011, 10:22 PM
4x484150's Avatar
4x484150
4x484150 is offline
My passenger side hub spins, but not freely or smooth. I have a feeling it might be the wheel bearing, but I'm not sure. I have looked around the forum here looking for info, and I'm also unsure of what the races are, or how to tell if the other bearings are bad. Thanks in advance.
Alan
Old 10-08-2011, 10:35 PM
Fordzilla80's Avatar
Fordzilla80
Fordzilla80 is offline
I can't help you on the diagnosis, but I can tell you what the race is. In lamen's terms, the race is the other half of what the bearings ride on. They call it a race most likely because it's in the shape of a high bank circular race track that the bearings "race" around. The race basically holds the bearing assembly in place and provides structure for the bearings to ride on.
Old 10-08-2011, 11:35 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Shaun is talking about 1217 & 1202.
Old 10-09-2011, 01:09 AM
muscletruck7379's Avatar
muscletruck7379
muscletruck7379 is offline
alot of our trucks are still running around with factory bearings and grease in the front end, so it probably wouldn't be a bad idea to replace them anyways.
besides the best way to see if they are bad are to disassemble and inspect, but with it up on a jack they should spin somewhat freely (with hubs disengaged, or you will have to consider the resistance of spinning the axle and the amount of drag the brakes have) you should feel for rough spots where they feel like they are catching on something. check for side to side play (stick a screwdrivers in the vents 180 degrees apart and rock it back and forth, but don't get too wild with it) they should have a very small amount of movement to account for when they heat up and expand while going down the road.
on that note, if they are too tight your hub will get hot while driving, but warm-cool is ok.
also, during lane changes or long sweeping curves a really bad set will howl.
Old 10-09-2011, 04:54 PM
4x484150's Avatar
4x484150
4x484150 is offline
Well, I took the wheels off, and tried to spin the hubs on both sides. Drivers side is smooth. Passenger side has those rough spots all the way around. There is no play 12-6, 9-3. Also before I took it apart, in addition to tire noise, there was a droneing noise which was constant. When I took the locking mechinism off, there seemed to be not enough grease.
Old 10-09-2011, 08:47 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Assuming a 1984 F150 4x4 (which your username implies) here is an exploded diagram of the hub; a repair manual, or probably the repair guides on autozone.com, will instruct you on dis-assembly & reassembly.
Old 10-09-2011, 09:20 PM
4x484150's Avatar
4x484150
4x484150 is offline
Thanks ctubutis. Gives me a better idea of what's in it before I take it apart. This isn't a hard job, as long as I have the right tool right?
Old 10-09-2011, 09:33 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Yeah...
You need a spanner wrench, but I forget what size....
Old 10-09-2011, 10:42 PM
4x484150's Avatar
4x484150
4x484150 is offline
Would this be correct? NAPA AUTO PARTS
Old 10-09-2011, 10:55 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
It looks like that, yes, but I'm not sure if the 2" size is what you need or not....
Old 10-09-2011, 11:56 PM
muscletruck7379
I know that autozone has the correct spanner available on thier loan a tool program, but any decent store should be able to at least show you the right tool.
Old 10-10-2011, 10:32 PM
4x484150's Avatar
4x484150
4x484150 is offline
All fixed
Thanks for the help guys. Got the hub/rotor off the truck today. Found some rust, half water, half grease, and scored races. All new bearings, races and grease put back in and rides a hell of a lot better. One more project done!
Old 10-11-2011, 03:52 AM
muscletruck7379
cool beans! I should do mine when i get home as well...
Psyclopse
1999 to 2016 Super Duty
04-11-2012 11:25 PM
arkredneck
10-24-2011 12:06 AM
seaweaver
11-03-2010 07:17 PM
89fourx4
09-18-2007 10:44 AM
omni
07-03-2004 05:10 PM
Quick Reply: Front end question-Solved
