Window wipers
Old Oct 11, 2011 | 04:36 AM
midsouth's Avatar
midsouth
Window wipers
Is is possible to put intermittent wipers on an 83 ford f 150 even though the existing wipers are low and high? Would I need to change the on/off switch?
Old Oct 11, 2011 | 07:58 AM
ctubutis's Avatar
ctubutis
Yes; you will need the governor (small black box) under the dash as well as the switch; the factory harness attaches to the governor, the switch attaches to the governor and also has a separate ground wire that screws to the dash and you're done.
I think this is in the sticky at the top, with a title something like 'wiring factory options.'
Old Oct 11, 2011 | 09:15 AM
Greyf100's Avatar
Greyf100
The hardest part of the swap is getting the old wiper ***** off, Other then the seperate ground wire screw its a plug 'n play deal!
Old Oct 11, 2011 | 09:51 AM
Stangrcr1's Avatar
Stangrcr1
Easiest way to find the intermittent in the JY:
If the wiper switch turns to the left, it has intermittent.
Old Oct 11, 2011 | 10:26 AM
ctubutis's Avatar
ctubutis
How to remove the **** (from Franklin2's diagrams):
gwindsor
Oct 21, 2016 11:02 AM
captain1997
Dec 17, 2011 05:16 PM
dmanlyr
May 21, 2010 04:51 PM
Imdok
Sep 9, 2007 05:03 PM
bronco4x4_3
Apr 25, 2001 02:22 PM
