Intermittent wipers?? (question)
you can get one out of a 87-91 ford truck, or 80-86 ford truck, I think 78 was the first year for them in the trucks, but there hard to find, they pop up on ebay alot. but basiclly all ford trucks used the same wiring connector so you can take that box and switch out of any later model up to 91 and put inter. wipers into anything back to, I think the early sixties.
it easy to tell just look at the part # on the gov. box if it starts with D8 (1978) its the 78-79 gov. box, this is the oldest part # I've ever seen. You can usually see it in the pictures on ebay so don't pay that big money for a original 79 gov. box when the part number starts with E7 (1987)
I took a look and saw I do have the control box for intermittent wipers. Although I can only seem to get one speed to work, Fast. I also noticed my washer fluid pump didn't work so I flipped the connector around and it still didn't work. I am wondering if the control box is faulty.
Hey y'all, reviving an old post here. I installed intermittent wiper controls on my 75 about 6 years ago using parts from an 87. The wipers have always worked fine however the washer never did but I didn't worry about it because I didn't have a reservoir anyway. Now I'd like to get them working because I'm moving to a state which does safety inspections and requires them. I read the information about switching the small plug around which I did but it made no difference. Then I noticed that the portion of the governor plug where the two lead plug connects only has one terminal and wire which is black with a white stripe. Can anyone help me figure out what's missing?
Did you try checking for voltage with the switch pushed in?
Josh
Take the old 2 prong plug and plug that in and try it either way.
No other plugs come off the governor, it's inline of the main harness.
The only oddball is attaching the ground wire. The rest is plug-n-play. So if the washer isn't working then something is broken somewhere.
Josh
Okay, it stopped raining so I went and did some checking in the dark. I've got power all the way to the plug under the hood when I push the switch so I should be able to pump fluid once the reservoir is installed. Now let me ask a question about the washer operation. Should the wipers operate when you push the switch in or do you still have to turn the **** to make them go.
#28
Okay, it stopped raining so I went and did some checking in the dark. I've got power all the way to the plug under the hood when I push the switch so I should be able to pump fluid once the reservoir is installed. now let me ask a question about the washer operation. Should the wipers operate and run through a few cycles when you push the switch in or do you still have to turn the **** to make them go.
Josh
#29
#30
Thanks for the info Josh. I guess the fact that there's only one terminal for the two lead plug is irrelevant then.
I was expecting the wipers to run while I held the switch in however. Even my 68 Cougar with the foot pump operates the wipers while you push on the pedal.
It's been forever for me, but I don't remember pushing the washer function and having the wipers cycle. Pretty sure it just sprays. Although, you wouldn't need the washer reservoir connected to check that, push the **** and wipers either cycle or don't cycle.
I'm pretty sure they do not, just sprays
Josh
captain1997
12-17-2011 05:16 PM
FordPickup460
24
12-04-2004 02:18 PM
F 2fifter with a 4 sixter
09-18-2004 10:59 PM
